Coil drill extention ?
dogdad
Down south
Is there an extension that coils or changes angle to drill screws in tight places that the drill won't fit exist?
jumbojak
Surry, VA
Dewalt makes a flex extension. It works but I wouldn't try it with an impact even though they claim it's impact rated.
DGersic
DeKalb, IL
A solid 90* extension is probably more useful than the spring drive adapters.
PhysicsDude
Dallas, TX
They make right angle adapters like this one:
https://www.homedepot.com/p/DEWALT-Right-Angle-Drill-Adapter-DWARA50/203867866
I have one, and I've used it a couple times. Its pretty awkward to use. I only use it if I absolutely have to.
There are also flexible extensions like this:
https://www.homedepot.com/p/Ryobi-11-in-Flexible-Shaft-Bit-Holder-A10FB1G/205193137
They're also pretty awkward to use. The last time I used one I broke it. Too much torque too much flex and the internal spring snapped in half.
DieselNut88
Northern,IL
I have a flex one. Pretty much useless. You cannot put any pressure on it or it just bends and flops around. I would get a 90 degree one if that will work.
