Hi Guys,
I've got a new house with a high efficiency furnace. The basement is insulated well and the house is very tight. As you can see from the pictures the cold air intake for the furnace combustion comes in and the pipe is open near the floor.
It's basically spilling out cold air into the basement constantly which is making the basement pretty cold. So I was looking for suggestions on how to stop this from happening.
I've been doing some research and some suggest to try putting a "J" pipe connecting to the cold air intake pipe to keep the cold air from spilling out all the time.
Other suggestions are to use a mechanical damper that is activated to open when the furnace turns on.
And other suggestions are to close off that entire area of the furnace and water heater so that the cold air stays in there.
The last 2 are a little expensive and the first one doesn't sound like it'll work (I've already tried a 5 gallon bucket under the pipe and it didn't do anything - cold air still spills over the edge of the bucket).
Suggestions?
Suggestions?
