TractorJeff
A guy in New York State has a cold room under his porch. He added a Coal Chute for the Trucker to dump the Rice Coal down. 4 ton is approximately 4 feet high in that room, if I remember right?
In my area people seem to mostly use them to store a fridge, or just Christmas decorations, etc.A guy in New York State has a cold room under his porch. He added a Coal Chute for the Trucker to dump the Rice Coal down. 4 ton is approximately 4 feet high in that room, if I remember right?
To the OP, the 2x4's and OSB can be removed. It's just a form for when the concrete slab is poured.
This was starting to be a somewhat popular amenity for new houses built about 8-10 years ago with hopes of utilizing more storage space or at the very least move the oil tank out of the main basement area. Seemed to catch on but then quickly tapered off and i rarely see that nowadays. The ones i've seen constructed have used corrugated steel as the structure to support it however i've heard of people having very humid basements and what happens when that warm moist air hits that cool steel ceiling?? Yup, lots of condensation to the point people couldn't store anything in there. Some houses did not have that issue so it depends.
6 feet
Yeah. That's what it looks like to me too, but I've spoken to a couple experts and they refuse to confirm that it isn't somehow structural (no matter how retarded that might be), so I'm considering just replacing it (and putting up the gasket and everything properly) before finishing it.It seems that you are good for the span with just concrete
Just an update guys:
I stripped out all the wood. What's on the photo below is the best of it, in the one area I just smashed it into mulch with a hammer.
Most of the rest of the room looks OK. I've fixed most of the water problems from the exterior, and will be repainting the one area of the porch next weekend.
HOWEVER, the side closest to the house (right at the threshold of the door) is even worse than I had expected. The previous owners had left it unsealed (I have since corrected it), but I'm a bit concerned about how bad the rot is, and the exposed sheathing.
I plan to have the ceiling spray-foamed by a professional, should I be doing anything above and beyond the usual exterior improvements and interior roll-on waterproofing?
What I'm seeing up there is brick... I suspect that they poured the slab after the brick was done, and some of it was included right up against the house.
That OSB, I am nearly certain, is the house sheathing. That would make the wood underneath (which appear to be 2x6s stacked) the baseplate for the framing of the main floor level of the house?Is that a 4x4 and some OSB still? Who knows what they were thinking when they designed that!
I have a concrete porch poured over a cold room, it's a pain in the *** and we don't use it. So would like to bring it into the house.
Curious to see what you ended up doing with this project and how it worked out. I've wanted to convert my cold cellar into heated/conditioned storage for a while now, but worried about doing it wrong and ending up with mold.
Dang just read this whole thread hoping get to see how it went. Didn’t realize how old it was.
I have some useful info about that, I'll include what I can with my update.Curious to see what you ended up doing with this project and how it worked out. I've wanted to convert my cold cellar into heated/conditioned storage for a while now, but worried about doing it wrong and ending up with mold.
