cold saws
Ironhorse74
MEMBER EMERITUS
The Pacific North Wet
I have been looking at cold saws. I will be cutting mostly steel tube and angles but want the ability to cut some non ferrous in the future. This will be in a serious home shop but not a professional shop. Always been a Dewalt guy so the DW872 jumps out. Since I don't know what I don't know. Is there another saw in that price range I should consider?
James-W
Southeastern Wisconsin
I have a Ryobi saw that is similar to the DeWalt saw that you mentioned and it works just fine. I also have a metal cutting bandsaw and I MUCH prefer the bandsaw.
I
Ironhorse74
MEMBER EMERITUS
shoot summ
This, I have the Rage saw, chips are awful, found a used Fem Saw, much better...
Fixed
Ontario, Canada
I am trying to figure out the difference between the DW872 and what you posted. From a specifications they are very close. Perhaps you could explain why the DW872 is not a cold saw.
My understanding is that a cold cut saw employs liquid cooling for the work piece, whereas a dry cut saw doesn't use lubricant.
Sent from my Nexus 5 using Tapatalk
dnschmidt
Phoenix, AZ
Cold Saw: Very industrial, Very Expensive and uses a steel blade with coolant always.
Dry Cut Saw: Moderately priced, Uses a carbide toothed blade and NO coolant. The best of these is made by M. K. Morse.
dr_clyde
Holland, MI
The main difference is blade RPM and torque. A proper cold spins at around 44 RPM and had a gear reduction off the motor for lots of torque. They use a solid HSS blade, and have full flood coolant, a nice vise, and usually a swivel head.
A dry cut saw on the other hand, is basically a nicer abrasive cutoff saw. They spin at a much higher rpm and are way cheaper. They don't come with much in the way of user features.
Get a band saw.
zkling
Get a band saw.
:+1:
Although dry cut saws, and even the more stout wood miter saws are great for cutting aluminum extrusion.
