Looking to cool my garage down during the hot summer midwest days. I have an artesian well where the water flows out without pumping into a tank in my basement-and then the excess flows out of the tank out to the ditch/river. The water is 48 degrees F and flows at 5-10 gallons per minute. I am thinking of routing the overflow of water (from the tank to the ditch/river) into my detached garage and having it flow through a heat exchanger/radiator with a fan to push air through it. Goal is to cool the garage down to a more comfortable temp without having excessive humidity. It should be minimal cost to run as the only cost would be to run the fan (the water flows due to ground pressure).
Concerns/Questions:
Is the the heat difference between the water (48deg F) and the air temp (75-95 F) enough to effectively cool?
Will the heat exchanger in the garage sweat excessively causing humidity concerns?
How much resistance or pressure will be required to push the water through the radiator/heat exchanger? The well produces lots of volume but does not have standard water pressure.
Is a junkyard radiator sufficient or should i splurge and get a heat exchanger?
Feel free to tell me where my idea will have issues/fail. Thanks for the help/input!
Concerns/Questions:
