Grzldvt
I have a 27 gallon Coleman Compressor that seems to seize up when the tank pressure gets to roughly 80 PSI.
I have a drain hose and when I leave it wide open so the tank does not fill and it seems to run forever and stays cool, when I close the valve about 1/2 way, pressure builds in the tank very slowly, the compressor motor heats up, not the electric one, and will sieze up and throw the breaker.
I have put fresh synthetic oil in it.
I did drain the oil, and only had enough to fill the crankcase about 1/2 way. Told my team NOT to use until I could get more oil. Found out they tried to use it anyway. I am thinking the compressor motor got hot enough to do some damage to itself, but under no load it runs quite nicely.
Thoughts?
Tanks in advance
Steve
Thoughts?
Tanks in advance
Steve
