I've seen a few online examples; see here: described as a 'Colone' screwdriver. Mine is identical to the one in this set.
I note mine also has the Colonel stamped so the L is under the handle and it looks like 'Colone'. However, I'm not averse to the possibility these were replacements of the originals of another brand, especially as this one seems too long for its place. Certainly, you see more of the Sorby style with a turned ridge on the handle rather than the smooth 'blob' style of the Colonel. I've seen good examples with RR on one side and Robt Sorby & Co on the other, but not Colonel. The only pics of Colonel style drivers in a RR/Bentley kit (with the smooth blob handle) have never been taken close-up enough to determine. There are a few references onling linking Colonel and Rolls/Bentley, but most are vague. The kits I've seen from around the late 50's onwards appear to have that smooth handle (different to the Sorby drivers). Maybe they were a good cheap replacement once someone took the originals for the household tool kit...
My example is quite a nice driver, regardless. The handle is very comfortable.
Cheers
Stuey
Just from a quick glance, first impression of that tool kit is that it is absolutely right, EXCEPT for the screwdriver!
I‘m not convinced it’s a Silver Cloud III tool kit anyway. Every one that I’ve seen has had a “King ****” adjustable, rather than the Garrington. I think it’s more likely that it’s an original Silver Cloud tool kit. You can’t derive much from the exact layout of the kit, as I’ve found considerable variation.
The Silver Cloud was introduced in ‘55, and every tool in the kit shown (screwdriver excepted) is absolutely correct for mid / late 50’s. The pliers are the earlier pattern Wilkinsons, the spanners are “Garringtons” not “Garrington” the adjustable is a Garringtons “Red Diamond”, and I can see “British Made” rather than “Made in England” on the Britool socket.
The Silver Cloud III wasn’t introduced till ‘62, and while it’s feasible some old stock items were used (certainly the Garringtons spanners) most that I’ve seen have some later tools, and all have had King **** adjustables.
Whatever that kit is off, I can guarantee that the screwdriver is wrong though. “Colonel” was definitely a Woolworths “house brand” by then, and Rolls didn’t “pop down to Woollies” to source their tools. By the time the Silver Cloud III was introduced, the “Colonel” brand had been replaced by “Winfield” and ceased to exist.
As you point out, the driver is also too long for the tray! Don’t let this stop you enjoying yours though. It’s definitely pre ’62!
Bear in mind also, that on any “coach built” Rolls (an option on the Silver Cloud) the tool kit would be down to the coachbuilder.
…and the contents to the customers requirement….
