Colored Concrete patio wet look coating?
joelw23
I have a new colored concrete patio, but when it's dry it has a whiteish coloring on the top, when wet, it looks brown as it should. Is there any coating that will give me a permanent wet look?
Thanks
Bronson
Texas panhandle
Why not contact the Company that installed it for You?
The guy that did mine had very specific instructions.
When I wash it, I have to blow it dry with leaf blower, or hard water makes it look chalky.
joes169
WI
Solvent based acrylic sealers are the standard in the decorative concrete industry. Higher solid contents generally enhance better, and last longer. As mentioned, OK the application with the original installer. (If this is new, he should have done the first 2 coats himself and gave you clear directions on future maintanence)
I would check prices locally at ready-mix suppliers, as they'll surely carry it. They're bound to be cheaper than the many different salesman that lurk here that should soon bombard this thread..........
J
joelw23
Seems he might be in jail....his business is no more
joes169
WI
A good solvent based sealer should help out.
Ready-Mix guys make great Ready-Mix, I never met one that made sealer, good or bad.
Good luck. :)
My "go-to guy" for sealers at the ready-mix plant I deal with most worked for Euclid Chemical for 8 years, he's got a pretty good idea what's going on, and I've always been able to get ahold of the company directly if there was ever an issue. They sell for a fraction of your prices as well, and I can pick it up the same day. Just letting people know theres' MANY other BIG sealer manufacturer's out there than just those here..........
Garage Flooring
Grand Junction, CO
You are absolutely 100% correct. Many times there are great local options and if you have one there is absolutely NOTHING wrong with buying the product locally. In fact, as you indicated it might even save you some money.
Those of us who are here are here to provide advice. Sometimes it starts to sound like a sales pitch, but the only legitimate footing we have for being here is to help you make the best decision for what is best for you!
Euclid Chemical is an awesome manufacturer. If your local Ready Mix is buying in large enough quantities they are likely bring the product in freight prepaid and they have no freight out costs. On a gallon of material that can easily equate to $20 +
My guess is they are suggesting something like http://www.euclidchemical.com/produ...based-curing-sealing/super-diamond-clear-vox/
Now keep in mind, acrylic sealers are maintainance sealers. They ABSOLUTELY will need to be redone from time to time. I am curious. Do you have a spot that is relatively hidden? What happens if you wipe the (hidden) area with some Xylene?
Assuming what you have there now is a solvent based acrylic, you can go back over it with another in most cases with very little prep work. Always test it first.
To be really really clear though, you will do it again at some point. BUT the alternative is completely removing the sealer that is there and going back with a urethane.
mark11
I use gloss high solid sealer on my patio. It's not cheap but it looks great and I get a few years out of it. If it's put on too thick it gets a white dusty look to it.
J
joelw23
There is currently no sealer on it that I'm aware of
J
joelw23
It's raining today, so here is a picture of it wet...
J
joelw23
Thank you .....that may be an option
boobag
thats colored concrete? must have used very little coloring.
