My apologies since this thread is almost two years old now, but I just acquired this same drill press and I can find very little information online about it. I have a couple of questions. Were you able to remove the JT2 chuck from yours? I've been unable to remove mine. Not sure if it's just stuck tight or if I'm doing something wrong. I tried using an oak dowel as a makeshift punch to tap downward on top of the chuck with a hammer, but no luck. I tried chucking up a large allen wrench and hitting downward with a hammer, but no luck. I've ordered a set of JT2 wedges to try and remove it, but I really want it off ASAP if possible. Looking for any suggestions.
My second question is if yours has the pulley speed chart. Mine did not nor is my motor labeled with its specs. if yours has a speed chart, would you mind posting a photo of it? Thanks.
Jason
No kidding? I know you used that on the body of the unit, the motor, and other big pieces. Are you saying you used that same paint on the tri-bar handle, belt tensioning handle, and the other little parts that were bright bare metal before they rusted? They look different than the other painted parts in your photo.Silver Metallic Rustoleum!
I think Keyblazer's Columbia and my Jet were both made by Orbit. My model number is OR-1412. It's probably the five-speed version of your 12-speed.Looks just like my orbit. Only changed the name tag.
