Columbian 504 Vise Info Thread (T-Jaw only)
sonoronos
Fixed base hole spacing (Side to side): 4.5"
Fixed base hole spacing (Front to back): 3.5"
Jaw width: 4"
Throat depth: 3.5"
Max opening (according to brochure: 6"): Reality: 5.5" (the limit where the end of the slide just disappears inside the body casting. I guess you could use it to 6" but I would be concerned about supporting the slide at that point.)
Length (closed): 17"
Static Jaw "neck" width: 3.5"
Dynamic Jaw "neck" width: 2.5"
Total Height: 7 13/16"
Beam casting dimensions:
Width: 2"
Height: 2 15/16"
Length of beam (until start of dynamic jaw rise): 10.5"
Lead screw diameter: 0.875"
Lead screw pitch: 4 tpi
Lead screw
Lead screw end diameter: 1.75"
Lead screw end length: 2.375"
Handle length: 11" (including ends)
Handle diameter: 0.62"
sonoronos
Image of the screw bushing. It appears to be made of steel fused to copper or bronze. It does not appear to be bronze in total.
  • 504_bushing3.zip
Vise504
I know this is an old thread, although I am restoring my grandfathers Columbian 504 vise. Was wondering if anyone knew where to source one of these from? seems that the wings/flanges have broken off
any help would greatly be appreciated
thanks
Sam
Vise504
overall 47mm
internal 25mm
the overall measurement doesn't include the wings as mine have broken off
