Columbian vise retaining ring is evil
Tbirkey
I pried the hell outta the retaibibg ring to get it off so i could paint my little d43 1/2. But its just like a washer with a slit with no spring characteristics. How in the world does ut go back on? Cant use snap ring pkiers cause they dont fit nor, does the collar really have any sproing to it.
T
Tbirkey
c4aBha
nda0av
tlmartin84
West Virginia
If it were mine and I couldn't get it to snap back on, I'd heat it up and spread it, then mash it back tight once on before it cooled.....
T
Tbirkey
That was the only thing i thought, heatin it up andcall. But how did the people at columbian getvem on originally? I bought this thing last night and it seemed fine. Didnt play with ut too much to know tim
T
Tbirkey
Went to the super ACE hardware in town and Grainger and they dont have any thick enough. I feel silly with 8 snap rings on there. Its about an 1/8th " thick. I might go get a butane pencil lighter at hardly freight and try to heat it.
T
Tbirkey
Over here at hf gettin pencil torch and crackhead just ran out with something big. At least steal something expensive.... That works!
T
Tbirkey
Im gettin real frustrated guys. Spent another twenty bucks and the pencil torch isnt working. Please help now im in enough for a new vice and a days work.
jakemac
New England
1982fxr
Phoenix
Yes shaft collar. Op is this the Columbian where the lead screw is exposed or inside the slide?
If inside the slide you may have to trim material off the outside. Ace will have the best selection after the pro supply houses. I did this twice but had to massage the o.d. For clearance. If it's the exposed lead screw style it shouldn't matter
1982fxr
Phoenix
Or an e clip, spring and washer if that would fit. A lot of Colombians had that set up too
Typically, under the U channel protecting the screw, at the front end, dynamic jaw, to keep the screw pulling the dynamic jaw out while opening the vise. Typically a notch in the screw for it.
Mtroy0620
Thanks. I am working with the same vise as the OP. This thread was very helpful in me fixing it. Unlike the OP, my retaining washer popped itself out somehow, so I have installed an E-clip. There is a lot of pressure backing out of a full close on the vise, which has popped the E clip out once already. There is no spring on this vise. So I am considering going the shaft collar route next.
You might put something to close the gap a bit. The gap on mine was 1/4” notch vs a thin clip, so jaw slop and ability to skew the clip. I think I used a hair clip style, and put a couple of washers in, so the clip is not bearing on the jaw while you open it.
Mtroy0620
Yes you are right there is not much room to work with. As far as I can tell the e clip or equivalent and a washer is standard on some vises. There may be room for one more washer but getting the clip on after that would be a real exercise in patience (in other words not for me). Can you give me a better idea of the clip you used? EDIT never mind, I think I found what you are talking about thanks.
