Columbian Vises
vwthingman
I just purchased a Columbian D44 vise. I have a couple of questions. Were Columbian Vises only originally red or other colors? There is a cone shape on the one side with a hole. What is that used for? Any help is appreciated
larry4406
Northern Virginia
My Columbian D4 was red when I stripped it down. Found a close match with Rust-oleum.
Sorry no help on your hole question.
Could it be a hardy hole, up on top? Located where if you put a fitting in there, you could whack it?
V
vwthingman
Thanks. That's the exact model of vise with the same hole. I understand that they had 2 models with the same name but only one had the "hardie hole" in it
GCS
Oklahoma
Mine is gray…
TheRealZeus
CONTINENTAL USA
I think you’re referencing the static body design of what it is called a “square shank cut off tool,” …the hole for said insert.
Columbian no. 44 advertisements for reference.
Here is one advertisement for the side cone form, I suspect you are referring to.
Hardware Age Sept. 27, 1934)”
Characteristic difference from the more-frequently seen, centerline, at back of anvil. example:
Hardware Age (July 25, 1940)
