I put up a post here on GJ like 2 weeks ago, about how "important" the swing arm safetys are on a lift, I still don't see the big deal/need for them...
But when it comes to the other safetys, the ones that keep the car from crashing down should a cylinder or cable fail, I definitely want those working.
I have a 2 post Weaver AFH 90, that I am about to put up within my garage; at current I am "going thru it" as I have rebuilt the cylinders, dumped the fluid out of the reservoir, replacing the bearings on the carriages, and such before I put it up, basically just doing alot of maintenance on it, to head off any problems once it's up. (I gotta clean out the "obstacle course" to make room for it yet as well, LOL.)
It has the individual safetys on each post, a little cable with a "finger-loop" on each post that has to be pulled out, so that the lift can be lowered.
At work, 3 of our 4 lifts (all 4 are ALM brand, 2 post, symmetric style) have a button that activates some small air cylinders to retract the safetys for lowering/ but it's a "single point" safety release as opposed to having to release 2 seperate safetys like mine has. How "hard" would it be, to retrofit my own lift, to have some sort of a single point release?
In my old shop we had Rotary assymetric ones (mid '90s models) that had a cable/pulley setup on the outside of the posts with a single lever that had to be held while lowering but it, too, was a single point safety release.
1 of our ALM's at work has the same style safety release as my lift at home does... but work can spend the money, to deal with the lift there....
I've got an old Rotary (the kind with the flip-up "adapters") that I use for them, because the newer ones are an even bigger pain to get under them right than the Rotary. That **** is sketchy, enough that I don't like anytime I have to put a bunch or torque on something by hand. I don't know that the arms would/could actually kick out, but I like knowing there's at least something keeping the arms from wiggling all over under those things.
