Combining 2 Switches into 1
tgasgarth
82EB9260-92C6-4146-9A67-B4C0732B1B2E.jpegI need help combining 2 switches into one. One switch controls the main garage lighting, and on controls a single light above the stairs to the garage. The main lighting has 2 other switches, while the light above the stairs is controlled by just the one switch.
How would I go about combining them? I have no prior experience with electrical stuff, but I can follow directions. Is this simple enough, or should I have an electrician do it? Also they are on the same breaker.
T
tgasgarth
Cap the hot to the left switch.
Tie the feed off the left switch to the traveler on the right switch. This get s but goofy because that's a 4 way....
i can't tell exactly how that's all wired, I'm not an electrician and I've been drinking so this advice is worth what you paid for it.
dont zap yourself or burn **** down.
Hmm. Might be calling the electrician
T
tgasgarth
looks like the switch on the right is a 2 pole switch? is that the one that controls the garage lighting?
Yes right controls garage lighting, left the solo light above the stairs. So I’m trying to integrate the solo light (left) into the garage lights (right switch)
Bert_
NW Iowa
With one being a 4 way I doubt you can do it without running another wire.
Is there attic above? Might be easier to just run a wire between the lights if you've got access.
T
tgasgarth
No it’s also finished space above. Do you think an electrician would be able to handle it?
walta
Dutzow Missouri
Since they are on the same breaker there is some glimmer of hope it could be done in the box but it is still a maybe and someone would need to take the time to understand what and how everything is wired and that seems more than we can do over the net.
Would it be possible to run a new wire between the two lights? It seems simple enough to connect to the working garage light and use the new wire to power the hall light.
Walta
T
tgasgarth
Walta
The area above the lights is all finished space. What I’m thinking of doing is running conduit to the light when I replace all the lights with proper fixtures. Then just deleting that switch.
the 4-way switch has travelers. if you use one of them to power the other light, it wont always work right since theyre switched by the 2 3 ways in the circuit.
exranger06
CT
Assuming this staircase has at least 6 steps, the current setup actually isn't up to code. You should have at least 2 switches for the staircase light: one at the top of the stairs, and one at the bottom. NEC 210.70(A)(2)(3).
So if you do combine the staircase light with the garage lights, you should still have a switch that controls all of the lights from the top of the stairs.
Milton Shaw
That gray single pole switch is a back stab switch. That is the kind that eventually those connections overheat and is why the NEC requires arc-fault breakers to stop fires. You need to check other switches and outlets and eliminate those back stabs from everything I have seen and numerous posts on this forum.
Maybe you could do what you want if that wire to the single pole comes from one of the other three way switches, if it comes from the three way switch that is powered for that circuit then you cannot do it. It would need to be connected to the other three way that powers the lights, switching current through the travelers. .
T
tgasgarth
The house was recently built as in finished 6 months ago. Is this something I should call up the electricians about and have them fix?
T
tgasgarth
It's 3 steps I think, like a 2 foot drop.
TractorJeff
Elkhorn, WI
I saw that right away!
Surprised this Thread went so long without someone else picking that up! If it was recently built/finished, I definitely would be checking all outlets and switches.
As far as the original question, OP states both switches are on the same Breaker. There is probably a junction in the box of one of the other 3 way switches?
DJF3
British Columbia, Canada
I'm new to this electrical stuff, but.....the OP says he wants the left switch gone. That's the single pole. Couldn't you just pigtail the two blacks from the single pole into the switched side of the three way? I don't know the best way to explain it. Seeing it in person would be much better. I'll bet a proper electrician could fix that in about 5 mins.
radrush
Atlanta, GA
Combining these two switches can be done very simply and efficiently by swapping out both switches out for Lutron Cassette smart switches.
Once installed, the Cassette switches can be controlled simultaneously one of several ways...
1. A Lutron Cassette "remote" can be programed (with Lutron app on your smart phone) to control both switches at once. Additional "remotes" can be used with wall-adapters and placed anywhere that you find convenient.
2. With the Lutron Cassette app on your smart phone, you can use Alexa or Hey Google to voice control the switches simultaneously as well.
3. Control the switches with the Lutron app on your smart phone.
Shiftless
East Bay SFO
How about wiring the stairs light permanently ON?
That’s not a bad idea.
With LED lights you could get a bulb using only a few watts. The cost to run that light would be negligible. Depending on your rates it might be less than $2.00 per year to run a 5 watt bulb 24/7.
