Great job! Overthinking is part of the process; better than the alternative.
I wired a 240V, 20A plug for it. The motor is rated at 12A but I wanted to make sure it would have an easy life without any voltage drop through the circuit.
Not sure if I have any good pics, but I had the trusses built with an extra 10" height for insulation. Therefore, I wanted to do the same around my attic hatch. I measured that I had just enough clearance on the sides of the hatch frame to build a 1/2" plywood box extending up to match the raised trusses. I then screwed 2x4 on each side of the plywood to sit on top of the bottom chords of the trusses. The whole assembly fit just right between the bottom chord of the trusses and I positioned it close to center of the shop to hopefully make entering/exiting the attic space as least awkward as possible.
Nice build! Where are you in NB? I'm in Bathurst lol.
For doing the ceiling what was your plan to get drywall up? Those stupid lifts only get you so high unless its setup on homemade scaffolding lol
I'm just outside of Fredericton now, career pulled me this way. Grew up near Moncton.
I see this is your first post. Welcome!![]()
Welcome to GJ!
I'm in Moncton but originally from the Dalhousie area.
Enjoying this build. Great work on getting the compressor fixed and wired!!
When I put the compressor up there, I had to assemble it piece by piece up there... frame, tank, compressor plate, pump, motor. After way too much thinking, that's exactly how I'm going to have to take it down to finish this wall. I'm sure the bark is worse than the bite, I've just been overthinking it for too long.Great work Dan...and nice job sneaking that lift in there! The PV10 looks like the real deal. My little lift has paid for itself many times over now..I can guarantee you will really appreciate that investment on a full height lift. 10K lbs should cover all your truck lifting needs too
Getting some heat and light going is next I would guess? What are you planning? I also notice that you decided not to install any windows for natural light...but I'm guessing you have a master plan![]()
