Commercial level grout cleaning
rslaback
Westcentral Wisconsin
The people who built our house installed white grout in the kitchen, dining and master bathroom. That grout is of course now a nice chocolate brown. We went after it once with scrub brushes and grout cleaner and it was better but the effort faded fast.
I'm not opposed to purchasing special cleaners and special tooling within reason as I prefer to learn new skills and possess equipment to paying for someone else to handle it.
Anyone know what tools and supplies the guys who do this professionally use?
duneslider
Riverton, Utah
Heavily dirty grout requires a fair bit of work to get it cleaned.
I would start out with a heavy duty grout cleaner like Aqua Mix Heavy duty tile and grout cleaner. This is non-acidic and should be the first step. This also requires a fair bit of scrubbing. I have some scrub brushes that I attach to my drill but I also spend a fair bit of time with a hand powered brush as well. This should get the grout pretty clean and get most of the soiling off the grout. After this step it is important to really flush the floor with water, this means mopping with clean clear water, wetter than normal to really rinse off all the residue and cleaner.
If the grout is looking pretty good then the next step would ideally be a good steam clean. This should loosen up any remaining gunk.
If the first clean didn't get it looking pretty good you could go to steam and try but that can sometimes force stuff deeper into the grout. This step involves using an acidic cleaner. Its important to remember that acid eats cement, so work small areas and flush clean after to remove the acid. Aqua Mix makes an acidic cleaner, there is also a Zep Grout Cleaner and Brightener that works well. With all these cleaners, really be careful with fumes, keep good airflow, cover eyes, wear gloves, etc.
This should clean things up, sometimes it takes a few rounds of step one. Remember that your grout didn't get this way in one day, so getting it back is gonna take some work.
Once you get it clean its a good idea to seal it and then consider your plan for upkeep and maintenance, which is a whole other discussion. Multiple ways to go with sealer.
Pros that come in and do the steam cleaning are just using more expensive equipment than the average person will have.
Nobody-named-Olli
We don’t have white grout - that might potentially need a lot more attention than darker grout colors.
When I clean the joints, I do it with a Kärcher (professional line, grey color) steam cleaner and no added cleaners/detergents. Just steam and about half a turn of water. Since our machine is long discontinued, I googled a bit, similar machines from Kärcher professional run between 1 and 1.5k (EUR) today.
Very stiff little brushes to go in/on the joints, then the floor attachment with a couple of rags to take it all up.
Works like a charm.
Unit has come in handy many, many times. Removing wall paper with it works fantastic as well. We also did have an iron to go with it (and an ironing board with extraction fan) ironing tablecloths & shirts had never been easier …
Edit: I just realized they are almost double in price in the US: https://www.kaercher.com/us/commercial/steam-cleaners/sg-4-4-steam-cleaner-10928050.html So you might want to check against comparable offers from domestic manufacturers/ brands.
Kind regards,
Olli
Dig Doug
Hire a good carpet cleaner! Make sure he has good truck mounted equipment !!
the machine can get up to 200+ degrees with pressure & **** - all at the same time !!
then seal it and maintain it
duneslider
Riverton, Utah
Humor me. I have no desire to be average.
Floor steam cleaner This is just the end tool, you still have to have the rest of the equipment to make it work. A full truck mounted setup that the commercial companies use is like 15k. It really doesn't make sense unless you plan to start a business doing it.
I would just pay someone to come and do it and then seal it if you don't want to put in the elbow grease to do it by hand. You can pole mounted scrub brushes to keep you off your knees for the most part, give it a good clean, get a smaller steam cleaner and then seal it up good.
The only caution I have with going straight to a steam cleaner without first trying to get as much off as you can with a detergent and scrub is that the steam and pressure can push contaminants deeper into the grout. It is has been sealed that isn't as much of a concern since the sealer is filling most of those pores already. Colored grouts it probably isn't as big of a deal either but white grout obviously is the most troublesome.
duneslider
Riverton, Utah
Grout removal is even more painful than cleaning.
Epoxy or urethane grouts are nice but still get dirty, they just generally don't stain.
