Commercial Warehouse Project
M5 LiTE
Herndon, VA
It's been a while, I've been busy, but this is happening!
I'm in the automotive service business in Northern Virginia. Been doing this for over 17 years and never has an opportunity like this happened before, so I'm taking this head on!
The owner of the business of where I'm at also owns multiple commercial properties, most with tenants. Just recently, a new warehouse was acquired and it's basically empty - it's to be developed into a multi-use facility to support the main business.
Dimensions are approximately 55' x 39' with 19' ceilings. Equipped with rudimentary A/C and heat. Concrete floor has been finished to some degree - appears to be polished (I'm not an expert but I know it hasn't been epoxied).
Lighting is basic with 6 LED high bays. Walls are concrete block and one is painted black (!!!).
Planned for the space is mostly storing/showing cars, and very light auto/moto/industrial work (such as media blasting/vapor blasting, parts cleaner, welding and detailing) but no greasy work.
The floor is the main concern right now, I'd like to get it so that the light work will not damage or stain the floors. It currently has tape adhesive all over, pockmarks and small cracks/joints that I'd like to have filled/repaired, then finish the surface inexpensively - doing the work myself with labor help.
I want to make sure tires do not mark or stick to the floor. I want it so water can be easily squeegeed/mopped (no floor drains - yet). Metal from grinding and welding doesn't damage the floor. Bright enough to reflect light. Minimal upkeep besides sweeping, occasional damp mop.
One 12x25' corner has carpet adhesive with net backing stuck to the floor. I want to get rid of the all surface residues, adhesives and stains and start fresh.
Where do I start and what products and processes do we use?
