Compact Air Hose Reel, can't find one small enough.
knever3
I have an I-Beam in the center of my garage and a limited space to install my hose reel on the ceiling. The maximum space is 15", I can't find ANY retractable hose reels that small, it can be wide like the hand crank ones are. Do they make a wide retractable hose reel? Every one I find is 19" and that won't work.
K
knever3
I did see the first one, but it's only 20'. I will need to see if I really need a longer hose or not.
GeoBruin
Harbor freight's central pneumatic 25' x 3/8" hose reel is exactly 15" from the mounting plate to the hose guide.
K
knever3
I just looked and measured my driveway and I would like a 35' hose, 50' would be overkill.
johnre
Portland, OR
I keep my air hose reel, along with the compressor, back of this panel that has a crawl space back of it - that way it isn't intruding into the garage / shop space. Is there a location where this could work for you?
K
knever3
Nope, It's a garage with cinder block walls, my compressor is tucked in the opposite corner. My hose is hung above so I have to squeeze between my car to get the hose. I should have known it was a bad idea. I have never had a hose reel.
