anythingyoucanimagine
Please forgive my ignorance. This is where my lack of NEC knowledge shows.
I have 120/240V residential split phase. I'm in the middle of a whole-home rewire (ahj has adopted 2017). I've got a brand new 200 amp square-d panel but not much more than that.
I'd like to run a short section of 10/3 from a 30A breaker to an L14-30 mounted on my panel's backer-board.
From there I would like to plug in an appropriately sized (for 30 amps) APC branded, listed, etc. battery backup unit (bbu).
I would then like to plug in one 5-20P and run a short section of 12ga soow to an outlet box with a receptacle on same backer-board next to panel. (this is where the g/a/combo protection will be) I then want to come out of that outlet box with 12/2 nm-b and continue the circuit into the house.
The battery unit is listed and internally fused to supply either 20A or 15A circuits (or a combination thereof as specified by manufacturer).
This is for a 20A branch circuit that supplies our internet/data/telco stuff. I know the inspector isn't going to have a clue about any of this... which is why I'm asking so I can have code rules/numbers to back all this up.
This is what I don't know:
The bbu has three 5-15r, two 5-20r and one 10-20r. I can (mechanically with internal disconnect switching) disable all but one 5-20R --but technically the device could supply more than just the one 5-20r. Is that OK?
I don't know about g/a/combo protection. I know twist lock doesn't need to be tamper resistant but can bring 30A with no g/a/combo protection out of a panel (in an attached garage) and run it to a twist lock receptacle next to panel? Do I need the 30A breaker to have any g/a/combo protection?
From there can I plug in an internally fused device that is listed and capable of stepping down to and supplying 120V at either 15A or 20A? I have not found anything in the nec that says I cannot --but I'm pretty sure inspector is going to have a field day with this. One dedicated receptacle, one device (with no g/a/combo protection)... Is that technically a branch circuit yet?
I believe I'm fine switching between nm-b and soow?? (as long as correct size, connectors, etc.)
Physical location: Unconditioned garage. Semi-conditioned, it won't get below 50-55F and humidifier/dehumidifier for moisture control. Battery will be up over 8-feet, I pulled a permit to change over two rafter ties to joists to support the ~300 pound load. Battery will be bolted to a support base built into the garage ceiling joists. All of this will be within a 6-foot radius of the panel.
Thanks. I think I provided enough info. Happy to give more info if I wasn't clear enough. Garage Journal has been an amazing resource. Thanks again.
Do you know Mike from Suspenders (the bar) by chance? He worked in the adult film industry long enough ago that it was actually film. Back in the 80's when stuff in NYC was dirt cheap he bought a building with a (ghetto --ask him to show you pictures, he's got a 3-ring binder behind the bar --it was ghetto) datacenter down in the basement. (right near 75 broad) He bought it to host ****. Today he's 65yo --ehhh... Maybe 70-75yo and he owns 5 (somewhat bottom tier) data buildings in lower Manhattan. All from ****. He doesn't do the adult stuff anymore (but he threw me one hell of a bachelor party). I should clarify --he is no longer an actor but he does have many clients that host god only knows what. Most of the chop-shop day-trading firms also run their garbage through his rack space. I get a lot of my clients from him. If they are legit (meaning 100% legal, above board, not doing anything shady, etc.) and they need better SLA/connectivity/service then I'm one of the guys Mike sends people to. I turn away more than I take. Don't want to jinx it but I've got a pretty good thing going --this Democrat tax on Wall Street transactions would absolutely F me and shut me down.
