Complicated file handle, Vintage?
4xdog
Santa Fe, NM
I think the same thing is available today. I have several of 'em. US-made still.
https://www.generaltools.com/adjustable-file-tool-handle
Provincial
Near Salem, OR
I bought the General one, but branded Craftsman, to hold needle files back in 1974. It is handy if you switch files often.
Seems over engineered to me.:headscrat
Maybe. With other vintage approaches, including Lutz, SKROOZ-ON, SHUR-GRIP, or even Disston's coiled spring ferrule, it wasn't one size fits all. You had to have a few different file handles for different size files. I'm not sure how much time it saves, if any, since in my experience it's just as easy to reach for a separate file-in-handle combination as it is to remove a file and reach for another file to put into the same handle. But it does save some space.
rlitman
Long Island
Imagine how many screwdrivers you could fit in a drawer if you only stored one of each size handle. You could have at least 10x the blades. The same goes for files. The down side is that files banging into each other in the drawer is bad for them.
Provincial
Near Salem, OR
I use mine for needle files so I can keep the files stored in the folding case. That way they are sorted and separated to make it easy to find the right one and protect them from damage. I rarely use more than one shape on a project, and it is even more rare to go back to the earlier shape.
srvctec
Central Kansas
Those are my all-time favorite file handle type. You can really crank down the tightening knob so it won't slip off the file while in use. I have one similar that appears to be called "vintage" now. It's the red handled Craftsman one (I think some sort of resin instead of wood) and the jaws are rubber coated. I think I got it in the 80's (I'll add a pic later). Wish I would have gotten 2 or 3 of them, I like them so much. BUT Nicholson has one similar now that I might have to get.
https://www.amazon.com/dp/B014IWD3OA/?tag=atomicindus08-20
Edit to add the photo and I guess it isn't Craftsman but Sears, so no lifetime warranty.
Tostal
The Emerald Isle
Those look clever, well made, strong and I have never seen them before. Probably yet another desirable tool only available the other side of the ocean..!
Even little ol' me here in Ireland had one of the Blue-Point GA 98 versions (as shown in post #9 ) back in 1979, I got it from the Snap-On tool agent.
T~
I have a few. Here are a couple of Generals and a Craftsman. Can’t have too many file handles, although I try.
-DonCCF88D76-2863-494B-8B64-00D39D13BC94.jpg2292D4D2-9569-4DF6-A5AD-425EA4E48BCB.jpgDBE3F6FB-A2BB-43C5-A980-B992D6502763.jpg
Tostal
The Emerald Isle
SuperCat
Sacramento, CA
Yet another tool I don't have....yet...lol.
But I do admit, I only have a couple of very used wooden file handles, which I can't always find when I need one, so I think a couple of these will be a big upgrade.
Thanks to everyone! Gotta go, have some shoppin' to do. ;^) :thumbup:
JZiggy
Atlanta
Wow, I never even knew I needed a file handle like this. Will keep my eyes open at the flea market!
I usually just got an adequately sized rod of hard plastic, drill a hole in one end, heat the pointy end of my file a bit and jam it in there. Takes me a while to wear out a file since I'm careful with them so this is at most a yearly operation.
ALLFAST
Cool info . Just walked by a green one from the new Crescent in my local ACE. It has 3 inserts (maybe 4) to accommodate different shapes/sizes of tangs, but I don't believe the end of collar screws on like these . It was about 7 bucks and plastic.
