Ranchermech
I acquired a Record vise needing one jaw insert bolts were sheared off. I ordered the replacements and received them the problem is the vise is tapped 5/16 NC and replacements are supplied 1/4 NC. Question is should I drill out the insert as it's hardened steel and regular bit don't touch it or machine a 5/16 bolt with a 1/4 thread in it? I was thinking start a pilot hole in the end of the bolt on the lathe screw it in with thread locker and then drill and tap 1/4". Seems more fun than trying to find the proper insert!
