midnight08
I will start off this thread with telling you that I know that there is a ton of information on this website about filters and regulators. I have searched and read through most of it... It has only made me more confused...
The question that I have is application specifics. Here is my compressed air setup.
Compressor:
- Quincy Model # 2V41C60VC
- 5HP
- 60gal
- 175 PSI Max
- 15.9CFM @ 90PSI
- 15.2CFM @ 175PSI
Compressed Air Plumbing:
- TransAir 7/8" Aluminum piping
Blasting Cabinet:
- Skat Blast Model # 800-T
- Requires 10-15CFM @ 80PSI
Hose Reel:
- Reel Craft 50ft 3/8in hose with 1/4 inch fittings.
I need to get a good set of filters and regulators for my blasting cabinet, and the hose reel, as well as a filter regulator set up for a drop that is over my lathe and mill for a general purpose blow gun.
From what I gather, I will need clean dry air for the blasting cabinet and the hose reel. The hose reel will need clean dry air as I will be running a plasma cutter off of it as well as my general tool use.
If I have my thoughts in order, I think I need something in the 1/4inch size as anything larger will not properly remove the condensate from the air. I will need a general purpose filter, regulator, and coalescing filter for the blasting cabinet, and the hose reel and a general purpose filter and regulator for the blow gun. One of the problems that I am running into is that most of the filters and regulators that I see that are in the 1/4inch size are only rated to flow in the 50 to 75PSI range. From what I understand, I need at least 80PSI for the blasting cabinet alone.
Some help would be much appreciated. I need some help sorting out all of this information.
Cheers.
Compressor:
- 5HP
- 60gal
- 175 PSI Max
- 15.9CFM @ 90PSI
- 15.2CFM @ 175PSI
Blasting Cabinet:
Hose Reel:
Cheers.
