brianflorida2024
- Joined
- Apr 9, 2024
- Messages
- 2
I am in the process of setting up a small at home business doing Cerakote (kinda like paint, but more for spraying firearms ect). This is the compressor I have and how someone I hired set it up. Not sure if he even did it correctly, kinda felt like he was on some drugs or something.
So the compressor has a quick release on the left side for the sand blast cabinet and then the blue piping goes into the attic and then about 40 feel later ends up in a room where the spray booth will be. The attic and the room where the compressor is, is not AC'd. I live in hot Florida so I am concerned that I will be spraying some water.
So as you can see in the photo, it looks like he installed a regulator. I gave him the box which contained
(1/2 in. NPT Deluxe FRL trio is a filter, regulator and lubricator all in 1. The filter comes with an automatic overnight drain, which will operate whenever liquid accumulates in the filter bowl. The regulator is the relieving type, which will exhaust air downstream when pressure rises above the maximum preset pressure. The drip type lubricator allows for precise setting. This pre-assembled unit has polycarbonate bowls with metal bowl guards, which includes a pressure gauge and 40 mic filter element. Offers a maximum of 250 psi and 100 SCFM. ) COULDNT POST Home Depot Link
this but he said I didn't need the other pieces. Not sure if he was right or not.
But I guess my primary question is.... What will I need to add to make sure there is no water/humidity in my lines when I am sandblasting or spraying (40') away?
I appreciate any help or advice you can give.
