I have a semi-portable, stacked (over/under) twin tank 1 1/2hp Emglo compressor hanging in the corner of the garage for blowing parts and airing up tires.
Accessing the two tank drain taps is difficult at best so they are not drained religiously. Very poor design in that respect.
The unit is very difficult to start up in the cold weather. It trips the internal 20a fuse although the compressor is rated at drawing 15a. It seems to have been that way for as long as I remember. So I did a bit of maintenance today and in draining the lower tank quite a bit of yellow mucous followed by a half cup of clear water drained out.
What is the yellow goop all about? Can that contribute to hard start up?
Also changed the oil (what little it takes....4 oz) to 0W30 Mobil 1 hoping that would help too. The manual calls for 30wt or 5w30, both noted as non-detergent. Unfortunately locating multigrade non-detergent oil isn't happening around there in this day and age. That would be why I am trying the low vis multi-grade synthetic.
Any comments would be welcome.
