Compression fitting for undersized OD copper pipe
Bmw4life
Canada
I purchased some 1/2 OD pipe from Amazon to install a cooler/radiator into my compressor, and turns out the pipe is a little undersized. Because of that, I cannot install the compression fitting.
The ferrule is a bit loose, so it doesn't get pressed properly, it always goes at an angle.
I can't seem to find a proper copper line, so I'm considering how to best make it work.
I'm thinking that maybe I can try to buy a flaring kit, but I have a feeling that it may not be able to hold the pipe tight enough.
I'm thinking it I could expand the pipe slightly, it's all that's needed to to able to use a compression fitting.
So I'm thinking this kit might do it?
Not sure if anyone has experienced this problem before.
rlitman
Long Island
Those expanding swages are meant for brazed tubing. I wouldn't trust expanding a pipe under an olive like that.
Have you looked for brass insert support bushings? They're required on plastic tubing to keep the OD from collapsing under the squeezed olive, but they improve the reliability of copper compression connections as well. In your case, you might need to hammer the bushing in. If you have a flaring tool, you could hold the tube about an inch from the end with it's clamp, rest that on the jaws of a vise and use that to make it easier to force the bushing into an undersized tube.
But you might not even need to force it in. The olive compresses the tube quite a bit, and the bushing resists that compression, improving the ring tension on the olive. Without the nut squeezing the olive, the bushings usually just about fall in, but once the fitting is squeezed, they're as permanent as the olive.
Bmw4life
Canada
Never seen these before but I'll look them up and try them!
u2slow
BC
You probably got 12mm tubing from amazon, not true 1/2" - due to the country of origin.
I would do the flare (if considered "soft" copper), or look for local supply of true 1/2" tube.
Bmw4life
Canada
would it be possible to solder a pc of 1/2" ( 5/8 OD) copper to the undersized pipe & use 5/8 compression fittings?
have you determined the pipe is undersized by measuring? ... return it to amazon ?
I would return it but I don't know where to buy the right pipe unfortunately. All hardware stores either don't have them or it's even worse quality.
Soldering might be a good idea but I've never soldered pipes before and don't have any 5/8 pieces. Could be a good idea if I can't find another solution.
Jim greengo
Behind my house
??? Tubing is normally sized by the id, not the od. What exactly did you buy and which compression fittings are you trying to use ? It sounds like you may have 3/8" tubing ?
Depends ,refrigiration tubing is measured by o.d
Sounds like it would be easier to just get a roll of 1/2" i.d copper.
fitter30
Peace Valley,mo
Try the flare. Sealing is all done 45° surfaces might want to oversize the flare. The swagging tool will make the diameter to large for compression ferrule. Soft solder a piece of m or l copper on it or make a bushing going into a fitting.
Bmw4life
Canada
For the flaring I need to buy the flare tool and the flare fittings. Still no guarantee the tool will grip the undersized tube...
I think this tool can control the widening of the tube
But first I'll try different ferrules
Bmw4life
Canada
I think you're right.
Actually before I try anything else, I'm gonna try 12mm ferrules intread of 1/2.
This way I don't need to return the copper tubing that I already bent and I don't need to buy more tubing.
I guess 12mm is 0.47 inches, so this might just work the easiest.
rlitman
Long Island
...I think this tool can control the widening of the tube...
I wouldn't touch that thing with a 10' pole. It looks like a terrible PEX expander being resold for a job it isn't up to. Might work for making brazed coupling joints on 3rd world air conditioners, but yeah, that's hot garbage.
Bmw4life
Canada
The brass insert, I tried looking them up. I would need them to be 12mm ID, and I don't see any for sale. They would need to be super thin walled as well.
rlitman
Long Island
The ones I've used all came with the compression fittings, and yes, they're damned near paper thin, but they do their job.
Bmw4life
Canada
You probably had something like this, but with 12mm ID instead of 8mm as in this case. The sleeve needs to go over the Cooper tube, so ID has to be 12mm for it to slide over. Here it's only 8mm.
The other thought I had was to use a "quick connect" fitting. But will try smaller ferrules first.
T444e
Tube is typically specified by the OD. However, like many things there are exceptions. Copper for refrigeration is called out by the OD while copper for plumbing and hydronic heating and cooling is called out by the nominal ID.
chinboys
I think Amazon or the seller on it mistakenly labeled the tubing. Others here have mentioned refrigeration tubing being referenced by its outside diameter.
This type of tubing is is called ACR... Air Conditioning Refrigeration.
Do yourself a favor and go to Home Depot to buy their type M or L copper 3/8 tubing that will fit your 1/2 compression fittings.
jkuro
Refrigeration copper is measured OD.
Plumbing copper is measured ID.
Aileron
outside
need to be careful with tubing measurments these days. Some of the foriegn made mini splits are a mm tubing. Had a couple guys putting a system in and could not get a hot work permit in the building so no brazing inside at the site. The tubing was a old ball size and had to take the indoor evap unit back off the wall and off site to a nearby commuter parking lot to braze a small piece of coppper on to it. A zoomlock or the new quick connects from parker would not hold becuase of the od diameter of the tubing.
joel63
Central FL
Only thing is I don't know where metric tube sizes fit into this grand scheme. :lol: :headscrat
T444e
Ones tubing and ones not.
Both refrigeration and plumbing copper is tube, as jkuro said, the difference is OD vs ID measurement being referenced. I've never seen seen copper pipe, only tube. However many people refer to copper as pipe, but it is tube. The OD of 5/8" ACR tube is the same as the OD of 1/2" type K, L, or M copper (5/8" OD).
Short answer, Europe. I'm not very familiar with metric copper, just know it is out there and seen it once. My only experience with metric copper is on hydronic heating and cooling panels from a German manufacturer. They use metric tubing in their panels and we had to sweat on metric x NPT adapters.
With the OP saying he got it from Amazon, the first thing that came to my mind is that he received metric tube. Now if he said it came from Grainger or McMaster-Carr it would be a head scratcher.:unsure:
Bmw4life
Canada
I purchased 12mm ferrules. 12mm ferrules fit on tight on that copper line.
Then the 1/2 ferrule fits on top of 12mm ferrule and provides a tight fit. I think this was the cheapest and easiest solution.
Bmw4life
Canada
Also used push it fittings with a bit of electrical tape. Seems to be working fine as well.1000066443.jpg
Bmw4life
Canada
Yeah used it to make it a bit tighter. I guess it might slide off at some point, but maybe it won't. If it does, I'll rearrange the connection:)
