Compression Water Elbow Fitting
firebirdparts
Kingsport, TN
No. You obviously could, but I’ve certainly never seen one, and there’s no real need.
The phrase ‘compression fitting threads like for a sink’ makes no sense at all, and that might be why no one answered. I chose to ignore that.
To me, compression fitting means compression fitting ‘nuff said.
P
Paulski
I'm not sure how else to describe the threads, I can not find any standard name for them. They are not NPT.
"Compression: A unique threaded fitting that does not mate with other thread types"
They are the threads found on the valves that you attach the water flex line that goes to your sink.
firebirdparts
Kingsport, TN
After sleeping on it, I think swagelock actually does make something like that in stainless. I have a hard time believing somebody would do it for plumbing purposes, though.
PCustoms
VT
firebirdparts
Kingsport, TN
I don't want to insult anybody's intelligence here, but a "male" side to a compression joint is a piece of tubing. So a compression elbow that is half male would just be a circle on the male side, dimensionally exact at the O.D. of the tubing. There is not much reason to make something like that, because all you need is a little tiny piece of tubing to stick into a regular compression elbow, and then you have it converted to a male.
P
Paulski
Basically I have a unit that has a water connection that sticks straight out the back, so when I push it back against the wall, i lose what ever the bend is of the flex line/risk pinching the flex line. I figure if I put a elbow on it, I get that space back since the water line will be coming from the top, instead straight back.
I measured the thread of the "compression" fitting - .540 OD, 24 TPI so its not NPST.
I found tees, this might be the best bet if I cap off one side and use it as a 90*
