Compressor 230v with 115v plug?
seber
Deep East Tx.
Years ago, it was fairly common to supply a 125 volt outlet with 240 and label it. 250 volt outlets were hard to get back then.
I don't know how common it was but my father had that in his shop running the RAS. That was a professional carpentry shop. It would have been done around 1955.
micromind
Fernley, Nevada, about 30 miles east of Reno.
What?
How many years ago was this?
In the 60s and early 70s.
I remember some DeWalt radial arm saws that had a voltage change switch built in to the motor. 110 or 220. The factory cord was 125 volt, I can think of several shops that had a basic standard 125 volt outlet that was supplied with 240.
Often, one half of the duplex was taped over, sometimes not.
johnre
Portland, OR
I think this was the one that was available until the early 1960s. The problem it had was that both 120 V ungrounded plugs (NEMA 1-15P, NEMA 1-20P) and 240 V ungrounded plugs (NEMA 2-15P, NEMA 2-20P) could all fit into it:
I've seen these in old houses. You had to know what the device needed, and how the outlet was wired, before you plugged into one of these.
I think this was the one that was available until the early 1960s. The problem it had was that both 120 V plugs (NEMA 1-15P, NEMA 1-20P) and 240 V plugs (NEMA 2-15P, NEMA 2-20P) could all fit into it:
And no ground plug. I remember seeing one as a child, in the 60s, probably a neighbor’s garage, never knew the excitement that was hiding behind that.
johnre
Portland, OR
And no ground plug.
Correct; added that clarification to my post. NEMA-5 and NEMA-6 grounded systems didn’t have this issue, except with the old NEMA 1-20P and NEMA 2-20P ungrounded plugs when used with the newer NEMA-5R and NEMA-6R receptacles.
seber
Deep East Tx.
My father's garage still had one of those for his radial arm saw when we sold the place a few years ago. At least he had tape over the other half with 240V marked on it.
Bert_
NW Iowa
What's changed? Manufacturers no longer lie about power ratings?
13.1 A @ 230 V would be right for four hp.
Not even close. 13.1A isn't much over 2hp maybe 2.5
You can figure about 5A per HP on these small single phase 240v motors.
