Hi guys,
I am planning to install an aftercooler on my 80 gallon vertical 2 stage compressor. I bought a Hayden 1260 oil cooler that others have used.
https://www.amazon.com/dp/B000HEADJ2/?tag=atomicindus08-20
I am planning to attach it to my belt guard since it's dimensions are ideal for my belt guard and I'd really rather not have the hassle or expense of an additional fan. The cleanest and easiest install is to mount the cooler with both ports facing upward. I just realized that this looks like it would be a problem with the condensate draining out of the cooler. Most setups that I've seen have either a cooler with the inlet port facing up and the exit port facing down, or both ports facing to one side. I am concerned that if I run mine with both ports up, the water won't drain from the cooler properly. And if I run with both ports down, water will remain in the inlet line. Maybe it doesn't matter?
Am I worrying about nothing?
Thanks for any input
