67King
Want to make sure I'm not missing anything. Have a 5.2 horse, 80 gallon compressor. Setting up everything in the new house, I have mounted it on an outside wall by the garage/shop. At the last house, I wasn't as good as I should have been about draining it since it was outside. Anyway, to alleviate that, I'm planning on an auto drain. Now, since I bought it, I've replaced most of my pneumatic tools with M12 and M18 stuff, so it doesn't get used that often. So, I don't want to have the auto drain connected and on all of the time, as it is conceivable that it would completely drain the tank between uses.
So my plan is to wire it to the pressure switch. Two questions along that line. First of all, is there any problem with that on that end of the circuit (i.e. the pressure switch or the auto drain)? I have already run 10/3 wiring to the compressor so I will have a neutral for it since it is a 120V, and the compressor is 240V. Obviously only the hot wire would come from the switch. SPecs on one that I have found state it only draws 4mA. I assume all of them will be similarly small, regardless of which one I get.
Second question is on the supply end. I assumed that I could just feed the drain off of the hot sides of the supply. Believe that is how ovens and other appliances that have 120/240V setups (i.e. a 240V that also requires a neutral). But I'm not positive. The breaker itself (30A, so way oversized for my needs) won't be affected by a slight current difference between the two poles, will it? In other words, am I overlooking anything?
