Daddyoneleg
Hello,i'm trying to put a compressor together and have a few questions.First of all this is what I have so far... The head is an IR 242-5n,the tank is an Eagle 80gal upright. I have purchased a Baldor L1410TM 1725 rpm single phase motor. I am trying to keep costs inline and need help with a Mag starter and a pressure switch. I don't know where to start.I don't want to spend the same on a starter as I did on the motor. The pump is a two stage 175 psi. Max rpm is 1040 and I have it sheaved to turn at 917 because @ 1040 the motor was drawing 25 plus amps @175psi on a test spin.I borrowed an amp meter from a friend. What starter and pressure switch should I use? Any help would be awesome. Thx.
Sounds like you are building up a nice compressor.
