Hi all:
I am no qualified engineer or have any experience with the above.
I have garage that can accommodate one big car. In the garage I have a 6ft x 4ft metal work table. In the garage I plan on working on my motorcycle, splitting crankcases, replacing car tires etc etc. for this these sort of jobs, which would be the most ideal air compressor to buy? I want something that will be worthwhile and not too light duty and at the same time not really heavy duty. Certainly, I will want to use air power tools as that would be the primary reason for buying an air compressor.
Having said this, which would be the most ideal configuration (How many Gallons, PSI, CFM etc. ??) to look for while buying a machine for the the above set-up? I've seen some machines listed as oil machines. Are they better than non-oil machines?
Thank you kindly.
Regards,
Daryl
Thank you kindly.
Regards,
Daryl
Most tire machines have some kind of bead seater built in BUT they typically also have a surge tank. Also anyone who does a lot of tires would like have one of those portable bead seater tanks.
