smalltown
I heard a couple of instances of fires starting from compressors not shutting off after closing up a garage. So I wanted to add a manual shut off without opening the garage sub panel each time.
I bought a small mini 2 ckt load center http://www.homedepot.com/p/Square-D-QO-30-Amp-2-Space-2-Circuit-Indoor-Main-Lug-Load-Center-QO2L30SCP/100157760. I installed a double pole QO breaker of which I had a few laying around. I would have preferred a shut off with a "knife switch" type on/off, but the only ones I found used cartridge fuses.
That said is it ok to feed the mini load center from my garage sub panel, and then bring the wiring back into a different knockout in the sub panel to route the wires up through the top of the sub panel?
