compressor drain ideas
azlo
dallas
I wanted to know if anybody had ideas for draining compressors easier. I hate the automatic ones because they dont last, so I came up with this idea. Dont have to lean over too, wich is a big plus for me.
<iframe width="420" height="315" src="//www.youtube.com/embed/wNCSuVD2deo" frameborder="0" allowfullscreen></iframe>
md21722
Mt Juliet, TN
Looks like ball valve he put a rod on.
Cool idea.
I make sure all my drains are extended out so they are easily reached and put a ball valve at the end. Then I bend over and put a jug over the end so it catches the water. I don't want the condensate all over the floor.
Duster346
Castle Rock, CO
I have piping and a ball valve on mine. I'm able to just open the lever with my foot as I walk by. Nothing fancy and super easy.
A
azlo
dallas
Yes, theres a ball valve at the bottom. Welded the lever to square tubing. I use to kick mine also but noticed that it would get loose. Thanks guys. By the way I read somewhere that somebody had rigged the drain to a remote?!?! I cannot find the post.
JJThrasher
Indiana
I put in a 90* and a piece of pipe with a valve at the end. I kick it open and kick it back closed.
lakeroadster
Central Colorado
I reach down, open the valve... when the water stops coming out... I close the valve.
Curious... what's the big deal with bending over?
NUTTSGT
Northern Central Ohio
I like that idea, simple, cheap and easy. Yeah, it's easy to bend over but some days after crawling under, over and in cars, it's nice not having to bend over.
redmondjp
Redmond, WA
It's a fine idea, so long as that pipe leg upstream of the valve doesn't fill up with moisture while the temperature on the shop floor is below freezing.
Art From De Leon
De Leon, Texas
When I added an auto-drain to mine, I kept the manual drain, which I had already extended out so I could use the toe of my boot to open and close the ball valve.
The tube went into a 5 gallon bucket.
fatfillup
Finksburg, Md
That is a great idea. Looks well done.
My compressor is mounted in a loft. We simply removed the petcock, install an elbow and hose barb, ran the hose down the loft support leg, installed another barb, ball valve, barb and a bit more hose. We drain it into the trash can that sits there anyway. One advantage is i have about 5 foot of hose for the condensate to collect in so it isn't setting in the tank.
byoungblood
Berryville, VA
I just have a ball valve mounted at the end of a 8" section of pipe. If/when I build my shop, I'll probably run a pipe outside to cut down the noise. Right now I just have an elbow that directs the air/water down.
