Compressor drain
Bellaireroad
Fort Worth
Who makes a good drain that works off the check valve , so that the tank drains when the compressor cycles? I'm not interested in the electric timer type of drain ... thanks
earthmover1980
South West Michigan
What we did with our air compressor is install a semi truck air tank drain valve, with the spring detent, and the pull cable. Done. At the end of the day, shut off the compressor, and pull the cable to drain it. Simple as that!
2oolhound
BC Canada
It won't let me link to the actual one I have. I fixed the link to go to the model. Mine is auto and it was about $100. Either they've gone way up in price or you just have to shop around. It's been very reliable for quite a few years.
Schurkey
^^^ What he said. About nine dollars.
https://www.napaonline.com/napa/en/p/TWR401070/TWR401070
https://www.napaonline.com/napa/en/p/TWEVEL032135/TWEVEL032135
https://www.napaonline.com/napa/en/p/TWRVEL032160/TWRVEL032160
The Cobbler
CJM8515
I thought about buying such an item for my compressor, but the cost is crazy imho. I find it easier to just get some small fittings, a ball valve and flip the valve when done.
The Cobbler
I agree the cost is high,which is why I haven't purchased yet, but,,, when you consider how much we spend on tools , compressors, etc, this is like cheaping out on tires on your cars IMO.
srr
San Diego
I thought so too until I read it was made mostly of SS and was rated for 300 PSI. Plus at my age crawling on the ground to get to my compressor drain PLUS remembering to do it once in a while. ;)
lakeroadster
Central Colorado
I'm a member of the DIY street elbow, pipe ******, and ball valve crowd.
Less is more... reach down, open the valve... when the water stops coming out close the valve.
I built a puke tank for mine using a Folgers can and some kitty litter to capture the rusty water.....
A flap cut in the lid, and a shop rag between the lid and can, allows the pressure to escape / vent.
easy peazy.
Curious... what's the big deal with bending over?
srr
San Diego
****. I never noticed that.
I have it installed on a two-stage compressor tank (175 psi) and it's been there a year.
I will have to research that and see what my options are.
Sounds like it's working OK to me, As long as your breaker is off when your not around the worst that could happen is it would lift and reseat at 120 PSI? Or drain the tank? :dunno:
srr
San Diego
easy peazy.
My current set-up (1977 CH 80 Gal 2-stage) is a short ****** with one of those butterfly valves that are really hard to turn and it is actually under the tank, a real pain to deal with. I'm on high BP meds and they make me nauseous if I spend to much time horizontal. :sad:
CJM8515
That I can understand. Im a young guy and dont mind bending down lol.
04chase
SO CAL
this is what i have on mine for now
https://www.grainger.com/product/CONRADER-1-1-4-x-1-1-4-x-2-68-Brass-12U302?s_pp=false&picUrl=//static.grainger.com/rp/s/is/image/Grainger/12U302_AS01?$smthumb$&breadcrumbCatId=2235
Schurkey
It doesn't lift at 175; it doesn't leak at 175.
I now have some concern that it might BLOW UP at 175...but it's been there long enough that I don't know how realistic that concern is.
There's also the idea that I can't find a max working pressure for the part number I actually have. The 120 psi max is for different NAPA part numbers, potentially a different manufacturer.
Yes, the compressor is generally turned off when I'm not there...although I did have a constant-run problem when an O-ring blew out on my filter/moisture trap. The compressor ran continuously for most of a day because I wasn't in the garage at the time.
srr
San Diego
Thanks, that's what I was looking for
Mine came today. One thing they didn't mention was, it HAS a screen on the tank side to keep **** out of the valve. Did you ever get yours? Anybody else?
srr
San Diego
Got it installed, works great. Hardest part was waiting for an 80 gallon tank to drain to "0". I bought the over priced installation kit as I couldn't find the filter/valve by itself. I made a video of it working but there is no sound but you can see the moisture appear in the hose around the 40 sec mark.
Bellaireroad
Fort Worth
I haven't .... it's on the "to do" list... thanks for posting the video, looks like it works good
smalltown
Western Maine
I'll bet it's not the bending over it's the getting back up :lol:
MacMcMacmac
canada
I drained about 40 gallons of water out of the instrument air compressor at work which had one of these pneumatic auto drains on it. I don't trust them to keep ahead of the condensate production.
I installed a timed auto drain kit and the tank is completely empty of water whenever I test it. In 25 years of working with air systems, I have seen maybe 2 that have failed.
Schurkey
There was a time I worked for a company that used an industrial scroll-type compressor, and a H-U-G-E air tank. I have an 80-gallon tank, I bet I could fit five of them inside this monster with room around each one.
The "parts guy" was responsible for draining the condensation from the tank. I don't think he appreciated this part of his job. My work-station was the closest to the tank, so I wound-up draining it now and then. It had a ball-valve near the bottom, leading to a short pipe.
We'd haul the water outside in 5-gallon pails, a dozen trips. The company had unlimited money for mandatory overtime, but couldn't buy a second torque wrench or a tank drainage system.
MacMcMacmac
canada
I had to hook up a hose to a 1500gal tank that was completely full of water due to someone's over zealous use of teflon tape on the drain fittings. 100psi can shoot water pretty far.
lbperry
North AL
Earthmover and Schurkey;
How do these work? Do you pull the cable; it drains and the pressure bleeds off; and it resets automatically?
Thanks,
Schurkey
Thanks,
The entire valve/mechanism is located on the drain pipe, except for the upper end of the cable which is mounted somewhere higher on the tank. In my case, it's mounted to the same platform as the electric motor that turns the compressor pump.
Pull the cable, valve unseats, tank drains...until you release the cable. With the cable released, the valve re-seats and the tank stops draining.
