Wondering is someone can help with identify is compressor. Currently I figure it's putting out about 1.5 cfm but the compressor is only running at 350 rpm I ordered a bigger pulley for the motor and plan on putting a two HP on it. I took the top off and plan on cleaning the Reed valves. The tube going to the tank is only quarter inch I plan to go up to 3/8 or half to hopefully get better air flow. Also what I think is the check valve isn't working. I was wondering if there is a way to calculate cfm based off bore stroke and rpm? Bore is about 2 inch in diameter and 2.25 in stroke. This is a really quiet running compressor I'm just hopping I can get it to flow a little better.
Sent from my Pixel 2 using Tapatalk
