Hey all,
I have been considering putting the compressor up in the roof space to so I can gain some more space on the floor and hopefully reduce the noise level. I just have a few questions.
The compressor has a regulator with a built in water trap mounted to it, the trap seems to pickup a lot of water, so would need to be drained quite regulary. Would sorta be a pain going up in the roof space just to do so.
I think I heard somewhere that there shouldn't be a trap mounted on the compressor anyway as it's always going to pickup water and should be placed further down stream?
Not sure what to do..
Should I just remove the regulator/water trap completly and run some gal piping and then add the reg/water trap further down stream where I have easy access to it?
Or is it a good idea to keep the regulator on the compressor?
Thanks
Thanks
