bowtieboy77
On the back of many bigger air compressor pumps there is a small copper tube that comes off the back of the compressor that goes to the unloader. Some compressors have the line some do not. What is this line for?
My old 5hp compressor pump had the line on it that tee into the tank check valve and the other side of tee goes to pressure switch unloader. My new pump does not have the line from the back of the pump. I believe the operation that will occur on my pump is when pressure reaches pressure switch cut out the pressure switch will disconnect power to the mag switch coil stopping motor. Also at same time the unloader valve will be activated which will bleed off the air between the pump heads and above the check valve.
Only purpose I can think of is the pumps that have this line purge crankcase pressure during unloading where as my new pump has a vent tube at the front between the cylinders. Is this correct?
