dreasoner
I'm sure this has been covered before. I want to add a maximum run timer in the control circuit of a 240V compressor that would shut the compressor off in the event of a predetermined run time. If the max run time is not reached the unit will cycle normally on the pressure switch. If the max run time is reached, I want the compressor to shut off and only be allowed to be restarted with a manual reset of the control circuit. I think this would be similar to a pick and hold circuit.
