After spending a lot of time laying out my garage space (still in progress) and spending a lot of time just reading threads on here I have a question.....
I have found a few threads through the search function about separating the pump on my compressor from the tank. This fits the bill perfectly for me because I have a great location in mind for the pump where I could mount it and sound isolate it that really can't be used for anything else (under stairs). I would obviously make sure air circulation was accounted for to prevent overheating.
My question is does the pump HAVE to be in an certain location in relation to the tank? I have high ceilings so I thought that if I could put pump the under the stairs and then get the tank up in the air it would make my life much easier by giving me more floor space. Would this cause any kind of issue? If that idea is okay would I use a hard line or soft line to plumb from the pump to the tank? Last would I need any items in that line to prevent damage to the pump or tank?
Thank you for your help; I really did try to search this question but couldn't find an answer.
