supersaiyan93
I have a 60 gallon vertical Campbell Hausfeld compressor that's about 12 years old. 3 HP 240V single phase motor.
I have used it for light duty work, always being very diligent to drain the compressor after each use, etc.
Any way, last night I went to use the compressor and the dang thing won't turn on. No buzzing, no tripping breakers, just no sign of life at all.
My troubleshooting so far:
I have 120V on each leg of the power cord.
I have 120V on each leg past the pressure switch on top (the tank currently has less than 10 psi in it).
I have 120V on each connector going into the motor itself.
Ground is good at the motor and the pressure switch.
My motor has a red reset button on the front, but it is not pushed out, and I can't push it in any more than it currently is.
I also disconnected the drive belt and turned the motor and the compressor by hand to make sure there was no mechanical binding.
Any ideas for further troubleshooting? I'm not much of a pixy wrangler, so any help would be very much appreciated.
I'm about to pull the front face to check continuity of the reset button on the motor to make sure it's still good. But other than that, I'm not sure what to check.
... I never had such luck finding parts like that........
