Try to get a better than 50% duty cycle on the motor, if possible. Also, make sure to confirm motor rotation before purchase. Otherwise I see no apparent problems.
I see many apparent problems, including the
likelihood that he would destroy his pump and/or not achieve a significant improvement in performance.
1. The math does not work using the numbers supplied.
1450 RPMs is 32% higher than 1100 RPMs.
12 CFM is 140% higher than 5 CFMs.
You don't get a 140% increase in CFMs by running the same pump 32% faster.
Since the math does not work, it means that the pumps cannot be the same.
2. Compressing air makes lots of heat. His pump probably doesn't have the cooling margin to support that kind of heat production.
3. The pump is almost certainly not capable of turning fast enough to flow 240% of its current airflow (12 CFM vs 5 CFM). Piston pumps, like piston engines, have "red lines" for RPMs.
Rescue Wagon said:
I have a Puma PK5020VP that is a 2-HP and rated for 5 cfm @ 90 psi. After some research it looks like the PUMA PK6060V which is a 3-HP and rated for 12 cfm @ 90 psi has the same pump.
I'm not sure what you found, but looking at the parts diagrams for each reveal numerous part number differences (pistons, cylinders, crankcases).
I looked and if the websites I found are correct here is the rpms for each...
I just bought a PK6060V and I can tell you that the 1450 rpm pump speed you quoted is wrong (it probably came from the Northern Tool website). Steve at Puma Air and Steve at Air Compressors Direct (two different Steves) stated that the pump rpm spec on the Northern Tool website is wrong. It's actually 980 RPM. You can see the correct specs here:
http://www.aircompressorsdirect.com/Puma-PK6060V-Air-Compressor/p591.html
Give a call to Puma Air at 901-744-7979 and talk to tech support. I was very impressed with Steve in tech support. He was genuinely enthusiastic and happy to spend time talking compressors, design trade-offs, upgrades, etc.
Realistically, your best, most economical approach is probably to sell your PK5020VP and buy a PK6060V from Northern Tool. They have them on sale for $500 and they will be down to $480 for Black Friday.
