Compressor/Nailgun question
coykiam
Hi All,
New member here. I currently have a 2 year old HDX 947282 small air compressor that was given to me. Recently I was doing some moulding work around the house using a punch and a hammer. I was thinking of purchasing a framing nail gun but was concern of how small and possible underpowered the HDX unit is.
The specs are: 2 Gallon
0.5 CFM @ 40 psi
0.4 CFM @ 90 psi
100 psi max
Will this small compressor handle the Nailgun demands or is it too weak?
WVUTampaAlum
Framing nailer for molding? Pick up a brad nailer. I have a HF pro one I picked up in 2004. I've run about 6000 brads through it with no problem.
EOC_Jason
Bentonville, AR
^^^ Yeah I would assume that is what he is talking about.
Brad nailers (and even regular nail guns) don't use that much air, the small pancake compressors should be sufficient.
WVUTampaAlum
Mine is a different color but basically the same. For a non pro usage it is awesome. Even came with extra rubber gasket and hammer mechanism which I still have never used.
bcradio
New Mexico
Hi All,
0.5 CFM @ 40 psi
0.4 CFM @ 90 psi
100 psi max
Are you talking about this?
http://www.harborfreight.com/18-gauge-brad-nailer-68021.html#.UyG-Qvu0zTo
For $19.99, I wouldn't mind picking one up...til I upgrade to decent ones.
I would put upgrading your compressor higher on the list than your guns
C
coykiam
I was just curious since this small one is obviously much easier to carry and wouldn't want to waste it. I have a bigger 20 Gal compressor in my garage I use for my other air tools. I don't know when I will be doing some moulding work but who knows, I might end up getting one of those combo kits for $200.
rlitman
Long Island
Just the air stored in the hose will fire a brad nailer.
Just the air stored in the nailer's handle. It's actually designed that way.
I've never seen a nailer that won't work off the smallest of pancake compressors. Maybe an airbrush compressor that doesn't make enough pressure (or have a tank) wouldn't work, but any pancake would be fine for any nailer. It's just that with bigger nailers, you may have to wait a couple of seconds between nails for the compressor to catch up. It's no big deal unless you're building a house.
skruft
I agree - if you are using an 18ga nailer any compressor with a tank is adequate. Note that with larger molding it is common to use a 15or 16ga nailer, but even that does not need much air.
