pelletman
Good Afternoon
My dad's compressor is an old Champion, 5HP 240V Single phase with a magnetic starter. Sometimes (often I would say) the compressor will try to start and it sounds like the starter is pulling in and it just buzzes, if you turn it off and on with the pressure switch switch it will start. It seems like it is worse in the cold and I think the problem is getting progressively worse. I realize start capacitors could cause this problem also, and my dad says that one of the start capacitors (at least) was replaced in the past, and they don't show any signs of physical failure, but it is the magnetic starter that is making the noise, and I just wanted to get some guidance here. If it is the starter (picture attached) can I clean or repair it (points?), replace the relays, or do I need to replace it? If I replace it should I go with an American unit for probably 300 bucks or the Chinese one for $60? Thanks for your input!
