Compressor oil vs engine oil
MackMan
Lexington, NC
OK I can't believe this hasn't been discussed before, but I did not find anything in search.
I want to change the oil in my new-to-me compressor. They say 10W30 compressor oil. I don't have any compressor oil but do have various auto engine oil laying around. Is there any reason to go buy compressor oil, or will auto oil work just fine?
:dunno:
b-body-bob
Almost Heaven
I use non-detergent straight 30w. You need non-detergent unless your pump has a pressurized oil system with a filter.
EOC_Jason
Bentonville, AR
You don't specifically have to use "compressor oil", you just want a non-detergent oil. Which every automotive oil has detergents in (Unless it specifically says "non-detergent" in big letters on the front)...
The detergents keep things suspended in the oil so that it will be carried to the oil filter. As most compressors are splash-lube, that means that it will be slinging stuff around that you really don't want.
Non-detergent oil on the other hand will allow things to settle to the bottom of your oil pan in the compressor.
JHAUK
Amsoil 40 wt synthetic compressor oil. No multi grades period. 30 wt nondetergent is fine if you can't find amsoil.
jmarkwolf
Southeast Michigan
Glad to see this thread.
I'm wanting to change the oil on my 11gal/3hp Sanborn horizontal, but the manual states only that 10W oil should be used.
The guys at the autoparts say that hydraulic cylinder oil is the stuff to use.
larry_g
oregon
:dunno:
Who is "they"? Can you link to the manual for the compressor that specifies what to use? You have received some suggestions from people who have no idea of what compressor you have, do you want to trust that information?
lg
no enat sig line
JHAUK
10w oil is for very frigid conditions, and if you forget to change oil come spring you will be looking for a new compressor. 40wt amsoil is what you want.
Sicbird
Haven, KS
I am glad to see this discussion as well...my Quincy manual shows the following:
5W for sub-zero F
10W for 0-32
20W for 32-80
30W for 60-104
It also has a note that the selected lubricant must have a pour point at least 15 deg F lower than the minimum expected ambient temp...which covers most heavier weight oils into pretty low temps. Lower than suggested by their chart, anyway.
But it holds 9 qts and there's no way I'm changing it back and forth at that expense. Do you guys successfully run a good synthetic 30 or 40w all year 'round, even at or below freezing? I thought about sticking a magnetic block heater on the thing to cheat for winter use...
MackMan
Lexington, NC
lg
no enat sig line
OEM manual from Kobalt
"The correct lubricant is essential to the proper operation of
your compressor, 10W-30 All weather air compressor oil is
recommended for general use." from p 18 which I have attached (whole manual exceeds forum limit)
  • Compressor.pdf
BUDSVTX
Destrehan La.
I agree with JHAUK. Amsoil 40 wt in my AJAX for years, over 500 hours on my compressor, still going strong.
BUD
zedbee
US
Hi pretty late to the thread but the use of motor oil is not recommended since it might contain some sort of detergents which may be beneficial for combustion engine but can be harmful for air compressor. Instead, you need to use air compressor oil.
