roaddog359
I have a 80 gal 2 stage ingersall rand compressor that I would like to change the oil on. What type of oil do I need to get for it? and where can I get it? and what is the cost? Thanks
(12) months from the date of placing the Equipment in operation or eighteen (18) months from the date
of shipment, whichever shall occur first. The foregoing warranty period shall apply to all Equipment, except for the following: (A)
Compressors that are operated solely on All Season Select synthetic compressor lubricant will have their bare compressor warranted for
the earlier of twenty-four (24) months from the date of initial operation or thirty (30) months from the date of shipment. (B) Replacement
parts will be warranted for six (6)
Air compressors work best with old fashioned straight 30W NON detergent motor oil.
They do not have combustion so they do not have corrosive blowby. They do not need all the modern additives in regular oil. They do not need synthetic base stock. They work at low RPM’s low load conditions.
Anything other than cheap 30W non detergent oil is a total waste of money.
Anyone who tells you otherwise is full of ****.
You can get it at walmart or any auto parts store.
I'm full of **** too I guess.. Nothing but Mobil1 10w30 for many years now and push that compressor hard.. No problems..
I would never let a compressor run to 8000 hours on an oil change. .
http://www.amsoil.com/storefront/sei.aspx
With proper monitoring, this oil is rated up to 8000 hr. My compressors won't run 8000 hr in my lifetime, so one filling of this oil will last longer than I own the compressor.
This is probably true for many people here.so one filling of this oil will last longer than I own the compressor.
I will, modern oils are so good that its usually a waste of effort to change earlier. With synthetics could go 25Kand I wouldnt lose any sleep. We have been extending oil changes of late. You could change oil every other weekend and it would probably add about 5 miles to the service life of a modern engine.Just like I wouldn't go 10,000 miles between oil changes in my truck....
