My air compressor stopped running this past weekend. No warning signs or weird noises. It cycled normally until the pressure switch cut off, then next time it should have started, it didn't.
It's getting power through the pressure switch to the motor. The pump spins easily, so I know it's not locked up. Neither the start or run capacitors are visibly popped or swelled.
Any way to check the motor (without disassembly)?
I've got both capacitors here with me and will test them using the maintenance shop's multimeter.
