Torque1st
MEMBER EMERITUS
The first blast will knock most of the initial water out. More water will accumulate tho. I usually try to anticipate and do things right the first time when it is easiest to do. The idea of a pit inside the building is what I was calling a dry well. The bottom is gravel so that water will drain. The cost of a tee and a short section of large PVC pipe is negligible.
The pit or dry well can be used for your electric entry also.
Are you going to bring water to your barn? The same pit can be used for your freeze proof hydrant. To get down below the frost line around this are means going about 3' deep. Call the codes department or county at your location.
