Hey guys,
I find myself needing some advice on compressor plumbing. What follows is a long lead-up to a "simple" question.
I have a large home shop (60x140) with 16' eves that is broken into 3 sections - 60x48, 60x72, and 60x20. The 60x48 will be used for automotive service with 2 lifts, one requiring air. The 60x72 will be used for general fabrication and autobody work, and the 60x20 will be used basically as a spray booth. It is generally just me in the shop, but I may occasionally have 2-3 other users. I plan on upgrading my T30 7.5hp 80 gallon compressor to a 7.5-10hp 120 gallon compressor. The compressor will land at the split between the 60x72 and 60x20 sections, meaning it will be roughly 20 feet in from the end wall. I was going to run piping out of the compressor into a few verticals and then through a refrigerated dryer before running it out to the shop. I figure I will burn somewhere in the neighborhood of 60' of pipe just on the verticals. After the refrigerated dryer, I figured I would run the line up to the ceiling down to the automotive service area with a handful of drops, probably about 9 drops around the 60x72, and a few in the 20x60. Near as I can tell, I am looking at about 600'-700' of piping and a bunch of Ts and 90s, with the longest run being about 200-250' (including the vertical "cooler"). Now for the question...
I am looking at the knock-off rapid air kits on amazon that are about $300 for a 300' 3/4" kit. Are these kits sufficient for the air usage/distance of this application? Do you have any advice about these kinds of kits (the good, the bad, and the ugly)? I'd much prefer straight sticks of pex-al-pex, but I can't seem to find it locally, so I am looking at these coil kits. Any suggestions on straightening out the coils?
Okay, so that was more than just a question.
Thanks in advance for any assistance you guys can offer.
John
