So I'm starting to do my homework for a compressor for my recently completed garage. I will be using die grinders, Impact wrenches and I have a large blast cabinet that I will be using regularly for amateur auto restoration. I have a 6' x 6' room dedicated for the compressor with 220V 30a breaker.
I will be running 3/4" Maxxline around the perimeter of the garge with (3) hose reels that have 3/8" air lines.
I'm looking for used to get more bang for my buck. Probably 60-80 gallon. I'm seeing the specs for compressors and most are in the 11 cfm at 90 psi and 5-7 hp. What pointers do you recommend out there? I'm seeing 1 and 3 stage compressors out there. I don't want a compressor hauling *** and making a ton of noise. I'd rather have one chugging and pumping air but I'm not sure which ones haul *** and which ones chug and still provide the air. Trying to stay in the $500 to $1k range used.
Any pointers would be appreciated.
Thanks
Thanks
