brotherbrown831
I am in the process of building a compressor sound proofing box for my HF 5hp 21 gallon compressor. I will post a thread about that in more detail later. Right now my question is about compressor shutdown pressure release valves.
Part of my design is an external switch that controls a 20 amp circuit inside the box for the compressor and the exhaust fan. If I shut down the compressor while its still charging by using this power cutoff switch the pressure release valve does not bleed off residual pressure in the pump. If I turn the switch back on the compressor must work very hard to get going again.
However if I turn the compressor off with the small switch built into the compressor the pressure is released and it takes no effort at all to start back up.
Can anyone help me understand what's happening here? Thanks!
